meeting over than 40 mints\100 audience | Community
  • May 14, 2024
  • 73 views
Greetings,
i used to do my work on zoom long time ago, i'm lost now
all i need is a meeting that will be for more than 100 audience and for 2 hrs, i don't know which bundle i should choose they change the upgrade options its too complicated.
regards,
iambobsat
Hi amaal,
I hope you are well.
Please follow this guide on how to do an upgrade.
Please take note though that:
Billing portal under Plans and Billing
  1. Sign in to the Zoom web portal.
  2. In the navigation menu, click Plans and Billing then Plan Management.
  3. On the Zoom Workplace Pro plan tile, click Manage.
  4. Click Edit Plan.
  5. Below the Zoom Workplace Pro title, click Switch plan.
  6. Select the plan you want to upgrade to.
  7. Select or enter the number of licensed users you want for this account.
  8. Select your preferred subscription cycle.
    Note: If you can’t make a selection on your preferred subscription cycle, you may have pending plans that impact your ability to change it.
    Contact Sales to make changes.
  9. In the Payment Method section, verify your payment details or click Edit to update your payment method.
  10. In the Updated Order Summary section on the right, review your order details, then click Place Order to complete your purchase.
    Your purchase is now complete and you will receive confirmation that your account was successfully upgraded.
    Billing portal under Account Management
    2. In the navigation menu, click Account Management then Billing.
    3. On the Current Plans tab, click Upgrade Account.
    4. In the box of the plan you want to upgrade to, click Upgrade.
    5. Enter the number of licenses you want and select whether you would like to pay monthly or annually.
    6. Click Save & Continue.
    7. Review the changes. If correct, click Save & Continue. If you need to change anything, click Edit in the section you would like to change.
    8. Click Place Order to complete your purchase.
Are you still facing this issue?
