Sep 13, 2023 1:22 PM UTC
Low Volume on Bluetooth Speaker with Mic on Android
I'm unable to increase the volume. While my Bluetooth speaker is loud when connected to Spotify and other apps, it becomes surprisingly quiet when using Zoom, and I can't raise the volume.
Participant
Nov 20, 2023 1:31 PM UTC
Are you sure that any sound is coming from the BT speakers; unless they have a microphone Zoom apparently won't connect to them althought the phones BT may show it as connected.
