Apr 28, 2026 6:48 PM UTC
Low bandwidth notifications and how to disable them
I work on the news and the most recent update screwed up our system and now if someone else has low bandwidth and we have them off camera it decreases the size of the shot and absolutely ruins it. I can't find a way to disable the low bandwidth notification and when I look up how online I either get outdated tutorials that don't work. Or it says that there's no way to disable the notification. If anyone has a solution please tell me.
Apr 30, 2026 3:29 PM UTC
Hey ​@Josiah Wester
Thank you for posting your question. Unfortunately, there is no way to disable the “low bandwidth” or “unstable connection” notifications in standard Zoom Meetings on desktop or mobile clients. These alerts are built into the Zoom client to help maintain call stability and cannot be turned off through user settings.
May 1, 2026 7:00 PM UTC
Well, could you send a note along to make the notification less obtrusive? The problem is that when the notification shows up it shrinks the camera and ruins the shot we’ve set up for the show. If someone could at least make it so the camera doesn’t shrink when the notification shows up, we’d be very grateful!
