Aug 5, 2024 8:17 PM UTC
Loud "Pop" sound after someone finishes commenting
I am responsible to look after the PC at a hall where Zoom meetings are hosted. I have received reports from 2 host users for 2 problems.
1- A loud annoying "Pop" sound after someone has finished commenting.
2- A sound when someone raises or lowers a hand.
Is there any way to stop these sounds? Your advice would be appreciated.
Kind regards
Chris
Humashankar
Aug 10, 2024 3:36 PM UTC
Hi @Chris_N1
Ensure Echo cancellation is enabled
Settings > Audio> try setting it to Low or Auto instead of High
Hope this helps - Happy to help further!!
Thank you very much and have a great one!
Warm regards
Chris_N1Author
Aug 11, 2024 11:47 AM UTC
Thank you very much Humashankar.  I will consider these suggestions and see how it goes.
Kind regards
Chris
