May 9, 2022 10:01 AM UTC
Login problem " We detected an unusual sign-in from a device or location you don't usually use."
We are a small non-profit with a Zoom Pro account that we share amongst different people.  That is, we have a number of different meetings all owned by the same Zoom account, but  different people run them and all those people have a need to log into Zoom using our one Zoom Pro account in order to run the meeting as Host..    Let's say that the one Zoom account is "***********" and note that one person only can log into that email.
Today, for the first time, someone got the message, "We detected an unusual sign-in from a device or location you don't usually use. If this was you, enter the code below to sign in to Zoom"  and, of course, Zoom sent the code to *********** but the person running the meeting was not the person who has access to the email!
You see the problem.  How can we turn off that security email?  I am aware that if we enable 2 Factor Authentication the verification email will not be used - but I don't think that solves our problem because each of the people who might need to run the meeting has to have access to that same 2FA SMS phone number or authenticator - so 2FA isn't going to work either.
We want to turn off that security email.  How can we do it?  This is a big issue for use as you can imagine.
    NSCTAnswer
    Feb 6, 2024 6:43 PM UTC
    This is an old thread, but I just found out that zoom now allows us to disable the one time passcode. It's described here:
    https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0058046
    Has anyone done this? If so how is it working?
    Jun 1, 2022 9:38 AM UTC
    Ive been reading the answers to this problem and ,
    1) the disable personal ID doesnt work for me
    2) i get the new code, use it, everything ok, and if i log off of zoom and turn back in 1 minute with same computer, It asks me for a new  *&@#!!!  code again,
    Not new device, not new location.
    I see last updates in the forum are 15 days ago... so i suppose  no  new clues?
    Jun 1, 2022 12:21 PM UTC
    We're seeing the same issue and it seems to have started at midnight today (2022-06-01). We have many accounts and some are shared by our 24x7 operations team for our hotline. The hotline was unable to log in or access the code as it is tied to a private admin mailbox.
    As with most companies these days, our staff sharing the hotline are geographically disperse and staff changes often. It would not be uncommon for a login on the US East Coast to be followed an hour later by a login on the US West Cost. Obviously impossible travel, but required for our business.  Zoom, please disable this or tell us how to.
    Jun 5, 2022 1:27 PM UTC
    Como usuários que pagam os serviços termos que ficar nos desviando de regras que o Zoom cria simplesmente para dificultar a utilização, minha empresa tem 5 licenças Zoom para que os colaboradores que estão em HomeOffice utilizem de acordo com suas agendas, e agora sempre que cada um vai efetuar o login necessita que o administrador das contas valide o código recebido por email, com colaboradores remotos isso é inviável!! Concordo que o Zoom controle logins simultâneos, mas não "onde" o login está sendo efetuado, quer fazer isso, então faça igual outros serviços, apenas sinalize o administrador do login, mas não bloqueie a utilização.
    além de tudo isso o email com o código muitas vezes demora a chegar, causando impacto nas agendas de compromissos com os clientes, novamente inaceitável o posicionamento do zoom, vamos homologar outros serviços de videoconferência, sinto muito zoom, pode ser um bom serviço, mas precisa ser solução não um problema mas as empresas que contratam seu serviço.
    ECSBCAuthor
    Jun 6, 2022 4:04 PM UTC
    The workaround that I described in my post from ‎2022-05-09 12:42 PM works.  We had the situation where a login triggered the security check and the that email from Zoom was detected by my gmail rule and sent to all of our Zoom administrators via a group distribution list I created called zoom-authenticators@......   You can see this in screen shot I attached
    Jun 7, 2022 6:00 PM UTC
    For what I can see, Security is just an excuse but to push more licenses. I think as a user, we should have those choices. In then end, if we don't care about the security, why should they care?  There are many options out there, I think if they push too hard, it is double edge saw.
    Jun 11, 2022 10:59 PM UTC
    We have a very similar situation.
    Jul 6, 2022 10:08 PM UTC
    We also have similar situation. In addition, after the new device has signed in using the Zoom-sent code, Zoom continues to NOT recognize the device at its next sign in.  Is anyone having that problem too?
    Feb 15, 2023 5:22 PM UTC
    Seems like this is a common situation. The solution suggested by ECSBC seems like a good one. So when someone from the team says they'd like to use the Zoom account, I just need to add them to my email rule so that any emails from Zoom are forwarded automatically to them. I once had a panic when trying to run a meeting in a different time zone, so the person who received the code wasn't even awake!
    ECSBCAuthor
    Feb 15, 2023 5:44 PM UTC
    Yes, naitrEnsemble.  We've been using this for almost a year now, and it works perfectly as long as you tell your people to look for that email and also that it might take a couple of minutes to get to them.
    May 16, 2023 8:56 PM UTC
    I have problem signing in.  System says there was security issue it will send me a code.  after sending a code i copy it and put it on the zoom request and it wont give me option to verify
    i tried it many times.
    i dont know how to post my question here !!!
    ECSBCAuthor
    May 16, 2023 9:03 PM UTC
    Hi biababa, I don't understand what you mean when you say you "copy it and put it on the zoom request and it wont give me option to verify."  Putting it in the zoom request is verifying it.  Please send screenshots.
    David
    Jul 20, 2023 11:37 PM UTC
    please tell me how I can sign into the meeting
    ECSBCAuthor
    Jul 20, 2023 11:40 PM UTC
    I don't understand what you're asking.
