Local recording too long and audio too slow | Community
  • October 16, 2024
  • 9 replies
  • 119 views
We saved a recorded meeting of 1.5 hrs locally, and resulting video file is 4 hrs, and audio is delayed and waaay too slow. What happened and can the files be fixed? Thanks!
Hello @PatS,
This can be an issue with the codec of the media player you are using. Can you try using VLC or Quicktime to play the recording? Let me know if this helps.
Hi @PatS!
Did you see the previous response?
Have a great day!
PatSAuthor
Hi, I tried playing with Quicktime and the video recording is still 4 hrs long, too slow, and the audio is delayed and too slow.  Can the recording file be re-converted or fixed somehow?
Thanks,
Pat
I'm sorry to hear that. For further assistance, kindly submit a ticket for a recording check performed by technical support on the backend.
In my ticket I stated that at least one other had the same problem, and pointed to this thread. The ticket is currently being reviewed. Not sure I want to share ticket number in an open forum.
In the meantime the ticket is being looked at. I have also uploaded the recording. After a few suggestions, I am now getting the answer that Zoom can see in their backend a high CPU usage on the computer on which I was recording. I had no other programs open (apart from virusscanners etc.). Does not seem a satisfactory answer. Have asked if recording in the cloud rather than the local device might make a difference.
join the club! I record my podcast on zoom and the last 4-5 episodes have my guest in perfect video and audio, while my own speech is so delayed I sound like a zombie. I tried every single possible trick on Imovie, Quick time, Garage band and its impossible topped up my audio! I am incredibly frustrated and I wish I could help!
