Mar 25, 2026 12:45 PM UTC
Linux search for contacts in Zoom Client 7.0 does not work
Hi!
 I’ve just upgraded to Zoom Client 7.0.0 (1666). The search bar on the top now pop up a window that is different from the app and where I cannot type anything inside. There’s an input for the search, latest searches, results divided by type. Only the X to close the windows works.
    zoomie7Answer
    Apr 1, 2026 9:46 AM UTC
    ​@yurj ​@John_Z  Could you help modify the zoomus.conf file by setting the value of `enableCefOsrMode` to false, and then check whether the issue is resolved?
    Mar 31, 2026 3:22 AM UTC
    Hi ​@yurj Thank you feedback, could you share screenshot. You can pixelate any sensitive information.
    yurjAuthor
    Mar 31, 2026 7:49 AM UTC
    As you can see below, when I type in “Cerca persone, ...” it shows nothing. But it works, I mean if I type the name of a know person and press enter, I get the chat on that person. So it seems that the drop-down menu does not show. Also, the window cannot be moved around, I can just close it clicking on the X. This is Debian 13, Zoom language: italian
    Mar 31, 2026 8:10 AM UTC
    I’m having the same problem on Linux Mint Cinnamon 22.3 and Zoom 7.0.
    The side bar isn’t loading and I can’t see contacts, or more importantly my reoccurring meetings. Clicking on ‘schedule’ on the left hand panel just throws up a blank screen which freezes and I have to restart the app.  Absolute shambles of an update yet again.
    Clicking on ‘join’ and then choosing a previous meeting is the workaround I’ve found for not having access to my reoccurring meetings. Hope this helps someone else.
    Apr 1, 2026 2:35 AM UTC
    Hi ​@yurj
    Thank you for reaching out to us!
    To help resolve this issue, please try clearing your local Zoom database by following these steps:
    1. Exit of the Zoom application.
    2. Delete the ~/.zoom directory from your system.
    3. Sign back in to Zoom and check if the issue is resolved.
    If the problem persists after completing these steps, please don’t hesitate to contact our Customer Support team — we’re happy to assist you further.
    Contributor I
    Apr 1, 2026 10:49 AM UTC
    Yeah, I noticed the same issue after upgrading. The new search popup seems buggy I also can’t type anything in it. Hopefully, Zoom releases a fix soon!
    yurjAuthor
    Apr 1, 2026 10:51 AM UTC
    the fix is “modify the zoomus.conf file by setting the value of `enableCefOsrMode` to false,” and restart Zoom.
    Contributor I
    Apr 2, 2026 5:37 AM UTC
    Looks like a bug in the new update Try restarting Zoom or signing out and back in. If it still doesn’t work, reinstalling the client might fix the search issue.
