Light theme does not exist | Community
  • June 1, 2022
  • 9 replies
  • 126 views
I want to enable Light Theme but the option is not listed where it should be according to this https://support.zoom.us/hc/en-us/articles/201362623-Changing-settings-in-the-desktop-client-mobile-app . Immediately under "automatically keep client up to date" (which is ticked) is Reactions: Skin Tone, then "display reactions above toolbar" then that is it.
How do I enable Light Theme ? And please update that guide, as it is providing incorrect info.
Thank you! (Using Windows 10 on laptop).
    Hi @ZoomUser13 mind attaching a screenshot of what you're seeing exactly? You're not seeing the option to select between Light and Dark themes for the desktop client? Suggest to try updating your Zoom client or uninstall and reinstall
    Attached. This is from the currently available download - I uninstalled and reinstalled from this presumably new up to date official version and as you see, there is zero Light theme mentioned.
    Additionally, why does it say "observer" under my name when I am a zoom user?
