Jan 27, 2022 3:20 PM UTC
Keep floating meeting controls and video panel from hiding part of a shared screen for participants.
When I am sharing a screen, If I can see the floating meeting controls and the video panel, those items block part of the screen I am trying to share, like part of a powerpoint slide.  Is there a way I can share a screen with the floating meeting controls and the video panel visible on my screen but not have them block part of the shared screen the participants see?
    Jan 27, 2022 3:31 PM UTC
    I have the same question. When I use PPT I share; stop sharing to be on screen w/o PPT and then go back to the PPT.  I know I can click on More each time to hide the controls. BUT is there a way to hide them to the viewer all the time? Thanks!
    Sep 4, 2022 6:07 AM UTC
    Hi RickC,
    I have the very same problem.  I want ALL the toolbars/popups/etc. to away when I screen-share, and I don't want to have to hide them again each time.  Have you gotten any feedback?
    Jul 28, 2022 4:44 PM UTC
    There is an option to Hide Floating Meeting Controls.   You can activate it using the shortcut [Ctrl+Alt+Shft+H].  Or by clicking the three horizontal dots on the right side of the floating meeting control bar.  That option should appear in the dropdown menu.  To unhide the control bar, press the [ESC] key.
    I hope that solves your problem.
    Jan 13, 2023 11:15 PM UTC
    I just discovered this topic and there's a big problem with the answer; the shortcut does indeed hide the controls but only until someone enters or leaves the meeting – the toolbar then appears and has to be hidden again with the shortcut. In meetings where people are always entering or leaving this renders the shortcut useless. Isn't there a way to permanently hide the meeting toolbar?
    Jan 19, 2023 12:17 PM UTC
    This problem just started happening for me as well, particularly when I check the "Optimize Video" box. The workaround was that the host of the meeting disabled the meeting room. But that no longer prevents the floating meeting toolbar from appearing everytime a new person enters the meeting. Only way I've discovered to prevent it is to NOT disable the meeting room--participants will NOT see your meeting controls, but YOU WILL. However, your video resolution is no longer optimized as a result.
    Feb 5, 2023 11:53 PM UTC
    There is a workaround using a second monitor.  Configure it in Windows as Extended Screen.  Do not use the Dual Monitor feature in Zoom.  Move the Zoom window to the extended screen.  Pop out the Participants window, the Chat window and any other windows needed for administration such as breakout rooms, and move them to the primary screen.  Open the window to be shared, move it to the extended screen and minimize it.  When you share this screen, click and hold the Floating Meeting Controls menu which will appear over the shared screen.  Drag it to the main screen so the shared screen on the extended monitor has no other windows over it or behind it.  When someone enters the waiting room, or when they are admitted to the zoom meeting, they will appear in the participants list on the main monitor but nothing will appear or cause grey boxes on the shared screen.  This workaround allows clicking the Optimize For Video button which improves the quality of video being shared, especially on low-end user devices such as cell phones.
    It is annoying to me that Zoom made such a significant change in an update in mid January without any warning.  We run meetings with people in a physical meeting room who can see the Zoom participants via a projector to a screen at the front of the room.  The new update in mid January causes grey boxes to appear during screen sharing for all zoom participants.  You can get rid of the grey boxes by unclicking Optimize For Video, but every time a someone arrives in the waiting room everyone's shared video freezes for several seconds, and then when you admit them to the meeting their video screen freezes again for several seconds.  Worse, the people in the physical room now have the floating meeting controls appearing over the shared video on the projector screen, and when you press Ctrl-Shift-Alt-H to get rid of it, a box appears saying to press Esc to get the floating meeting controls back.  This happens for the people in the physical room every time a person enters the waiting room and every time someone is admitted to the meeting.
    Prior to the update in mid-January, pressing Ctrl-Alt-Shift-H caused the pop-up Floating Meeting Controls to permanently disappear.  We used a separate computer to do administration so screen sharing was relatively fuss-free.  Now we are having to order second monitors for all computers doing screen sharing, and find space for them on audio/visual desks with somewhat limited real estate.  Ugh.
    Feb 6, 2023 12:05 AM UTC
    Really appreciate this detailed information. But for those of us without the ability to utilize a secondary monitor (primarily because of real estate on our desks), it’s a horrible workaround. I’m hoping Zoom has gotten enough complaints about this situation to correct it on the next upgrade.
    In the meantime, I’m left to uncheck the optimize video when I share the screen for my powerpoints with embedded videos. And based on the responses of people participating in my zoom, this has NOT impacted video quality (and I”m often in zooms with dozens of participants). Yes, my screen looks a mess with the floating meeting controls always visible as well as the views of the participants (which of course can be minimized).
    I am frankly surprised that NOT using optimized video has seemingly not affected video quality. Has this been anyone else’s experience?
    Again, many thanks for your instructions. Now if only I had room for a biggest desk!!
    Feb 6, 2023 12:47 AM UTC
    Doug: Yes, thanks so much! Can't remember if I mentioned this before but I've been emailing and calling with Zoom tech for a month, more than 60 emails, and the conclusion was that it was intentional (what?!) and my venue, UCLA, could institute a Feature Request (shouldn't it be a Feature Repair Request?) but there were very few other people with this problem and they probably wouldn't do anything about it. I'm going to forward your reply as well as bgrose's to them and see if that helps.
    Meanwhile, though, I've been experimenting with your workaround and it doesn't work for me, but I may not be doing it right.
    First, a small thing: you say "Open the window to be shared, move ito the extended screen and minimize" – by "minimize" do you mean make it smaller or make it go Windows toolbar? I'm assuming the former.
    Then "When you share this screen, click and hold the Floating Meeting Controls menu which will appear over the shared screen (etc.)." For that there's good new and bad news; the good news is that the menu/toolbar isn't there! Which would solve the problem except that the app in the shared screen doesn't work.
    It's PowerPoint, and it's on the Main screen; I open it there, drag it to the Extended Screen, start the Slide Show, but the Slide Show opens on the Main screen where it works just fine... which is of no use, because the open PowerPoint on the Extended Screen doesn't do anything; it doesn't expand to full screen and it won't play.
    I'd be really grateful if you could address this but I also wonder if this is something we could discuss in a Meeting. Either way, I appreciate what you've already done.
    Feb 6, 2023 1:07 AM UTC
    Why would Zoom want to “enable” this configuration? How does it benefit them—or any user? I’m hoping this is just a coding glitch that will somehow be corrected in the next update
    Feb 6, 2023 1:18 AM UTC
    bgrose: As near as I can understand what I got from the Supervisor at Zoom Support, it was instituted for some reason unconnected with Optimize Video or Meeting Toolbar but they consider that problem to be small and affecting only a few people.
    Doug: I'll go back and try again with this new information, but maybe not right away. (My brain's starting to fry from all the things I've experimented with.) A couple things, though, which I think may mean it's unlikely to work for me...
    1: Yep, I know about the Meeting Controls disappearing after five seconds – that's what happens if you click Optimize Video. But having that toolbar appear then disappear every time someone enters or leaves the meeting isn't viable.
    2: Yep, PowerPoint has a setting under Set Up Slide Show where you can designate the monitor you want the Show to appear on; the only choices are Primary and Automatic, and I've designated Primary. So I'll try Automatic.
    Meanwhile, I've forwarded all these recent responses to my Supervisor contact, who's been responsive though hasn't been able to get any action taken so far.
    Feb 6, 2023 3:51 AM UTC
    Sounds like you know more than me about some of the software behaviour.  And thanks for forwarding this information.  Regarding which monitor does what with Powerpoint, it may make more sense to leave Powerpoint set to Primary.  It is probably telling which monitor does what from the designation made in Windows.  To check this, make sure both monitors are active.  Right click on the desktop and select Display Settings in Windows.  There should be a graphical representation of both monitors.  Select the one you want to be Primary in Powerpoint, then click "Make this my main display".  I think that determines which monitor in Powerpoint has the speaker view and which shows the Powerpoint slide to be shared within Zoom.
    Again, I am certainly not an expert, hope I am not wasting more of you're time.  🙂
    Feb 6, 2023 4:49 AM UTC
    I know a bit but so do you! And yep, I know about checking monitor identities – I do it constantly 'cause I constantly forget which is which. (The one I consider my primary inevitably ends up as "2".)
    As for wasting my time, it may be time down the drain but it may not be, so you're doing me (and others reading these as well) a huge favor; given that you've beaten the problem, it's worth some effort to try to replicate your result.
    The main thing to me about what you've passed on is something that may seem small to you – the idea that you can drag the menu toolbar off the Zoom window. I had no idea that was possible and if I can do that, it could well solve the problem.
    Here's hoping. And in any case, thanks!
    Feb 6, 2023 6:42 PM UTC
    It depends on what you want to show to your meeting participants and where they are located. Zoom's Dual Monitor setting puts people on the main screen and shared content on the extended screen. As long as all participants are viewing the meeting via Zoom, especially with each of them having a dual-monitor setup themselves, it works great. But the first issue for us is that we have some participants in a physical meeting viewing one of the screens via a projector. The projector has to be wired to show a duplicat copy of either a) the shared content, or b) the people on Zoom. It cannot be switched between them easily. In addition, for Zoom participants with only a single screen, such as a cell phone, they will only see the shared content, never the meeting participants again.
    Our meetings use a projector, and we want the people in the room to see the people on Zoom, unless there is video being shared in which case we want all participants (physical and Zoom) to see the video. That can only be achieved with Dual Monitors unchecked. I move the Zoom window to the extended screen and use a Y cable to create a second HDMI copy of that screen which is sent to the projector. The primary screen only contains administration windows from Zoom such as Participants, Chat etc, and none of the meeting participants can see the information on that screen which is OK because they don't need to. When not sharing video, people in the room and on Zoom all see the other meeting participants. When sharing video, all participants are automatically switched by Zoom to view the shared video - true even for users with a single screen such as a cell phone. When the video is done and the administrator stops sharing, all participants are again switched by Zoom to show the meeting participants, even those with a single screen.
    This is why I said a few posts back if the problem behaviour in the update is fixed with a "new feature", I am interested in exactly how the new feature is designed to behave. There are important subtleties.
    I don't know how unique our meeting configuration is. We want the participants in the room to be able to talk with the participants on Zoom. They can do this by walking up to the podium - we have a camera at the back with a telephoto lens which is input to Zoom so the Zoom participants can see and talk to the person at the podium. The big projected screen is behind the podium which is hard for the speaker to see, so we put a laptop at the podium with audio and camera shut off, set up as a "dumb" meeting participant, so the speaker can see and converse with the Zoom participants by glancing down at the laptop.
    We recently made a change because some participants in the room feel shy or intimidated about walking up to the podium to talk to everyone in the meeting. So we put another camera at the front of the room facing the audience, and we have a roving microphone available for people in the building. If they want to interact with the people on Zoom, they speak into the microphone from their chair in the audience, and I switch the video feed in Zoom to the camera at the front which shows the person in the audience to everyone in the room as well as to the participants on Zoom.
    It might sound too complicated, but everyone got used to it pretty quickly, even non-technical people. It lets us hold a meeting in a physical building but invite participants via Zoom from anywhere in the world, and everyone can talk and interact with everyone else. Non-technical users can fully participate in the meeting and interact with all participants even with just a cell phone, even while driving a car. We love Zoom! Except when they do a new release that suddenly starts showing menus and grey boxes on all the screens during the shared video...
    Feb 6, 2023 8:32 PM UTC
    It does indeed sound complicated but it also sounds like every step of it was well thought-out and works, which is great.
    About your answer to my smaller question: you say "As long as all participants are viewing the meeting via Zoom, especially with each of them having a dual-monitor setup themselves, it works great." I know the last part of that applies to your situation but it doesn't at all to mine. So if none of the participants has a dual-monitor setup, do you know what effect the Host's disabling the duel-monitor setup have? It sounds like maybe it's not necessary to disable it.
    Feb 6, 2023 6:48 PM UTC
    Sorry, dm51, that lengthy reply was to a posting that I saw from yourself that seems to have disappeared now.  Not sure what happened.
    N5JJR-aAuthor
    Feb 6, 2023 7:16 PM UTC
    Thanks Doug_M
    If the reply you are not seeing any more starts with: "It depends on what you want to show..."  I can still see it in this thread.
    Anyway, we have come up with something that is working for us.
    Thanks +++ 🙂
    Mike
