Issues with Zoom and W11. | Community
  • October 17, 2024
  • 3 replies
  • 98 views
Hello! It's my first post here. I will try to be as understandable as possible. A few days ago, approximately October 8, I received the Windows update and just Zoom as well. Well, I updated both and after that the audio during the university meetings (which is a distance course, that is, only by Zoom) started to get stuck every time I changed the window, from Word to Zoom, from Zoom to Chrome and so on. I always worked with 3 windows open, precisely those: Chrome, Word and Zoom, and even though my laptop is of low specifications, I never, ever had a problem.
But anyway, I thought it was the Bluetooth headphones and I left it with the laptop speakers but it kept cutting out every time I changed windows and I started to rule out problems.
i did this:
-I updated the drivers, everything, not just sound. Nothing.
-I did a "stress" test to see what happened: MP3 files in the player, 2 tabs with Youtube, Spotify and Zoom. Yes, only zoom was stuck. The rest was going well and the PC didn't even crash.
-I removed zoom and reinstalled from 0. I also tried with old versions to rule out a defective version and nothing, all with the same problem.
-I gradually removed Windows updates and nothing...
-I tried an external USB audio card to check hardware, it was still the same.
-I only tried Zoom, in test mode, it also crashed and...
And I decided to reset Windows from advanced boot, with the deletion of files, everything was deleted, Windows was downloaded, installation and so on. It doesn't work, the audio keeps jamming;
I leave my specs in case you need them.
Windows 11 Home Single Language
Intel N4020, 2.4Ghz, 8RAM, 256GB SSD
ZOOM version 6.2.3
Note, if my english is rare, i used translate, i speak engkish but not enough and if exist any error y beacause translate.
I have a similar issue, new PC with W11. every time I open up any website with video streaming and Zoom, audio quality is significant impacted. Youtube sounded terrible. It went back to normal as soon as I close the Zoom app.
Both a/v quality on my new Dell W11 are much worse than on the W10 HP I had. I have no clue what to do or who to ask for help.
By accident some AI settings popped up, and I disabled the AI setting on the laptop, with W11. It solved my problem.
