Oct 6, 2025 8:28 PM UTC
Issues with Juniper SRX and Zoom Meetings
Hey All,
I am experiencing a weird issue, and I can't for the life of me track down what is going on.  Some brief background:
  •  I have a Juniper SRX340 running JUNOS 23.4R2
  • I join my meeting via my Mac which is a 2023 M3 Pro with 36GB of RAM
  • From my Juniper SRX I connect to 2 Arista 7280's in an MLAG setup, which feeds my Arista 720 and Arista C330 AP's
  • I am joining all my meeting via Wifi - where my recent speed/bufferbloat test show nearly 1Gbps symetrical and A+ rating for no bufferbloat.
Symptoms:
During my Zoom meetings calls will typically start relatively normal.  At some point during the call, but always within the first 30 minutes, I will start to hear choppy audio and frozen video and I get the message "Your Internet Connection is Unstable".  Ultimately after a few minutes of really choppy audio, the call drops and reforms.  Sometimes this is the end of it, sometimes it isn't and this cycle can go on for 15-30 minutes.
On the network side of things, I look at my logs and I see my port-channel/AE has dropped due to LACP timeout.  This is odd, since there is no queue exhaustion, between the Juniper SRX and the Arista 7280's.  I escalated a case with Arista and it seems to be a Juniper issue.
That being said - Zoom is the only teleconferencing service that causes issues.  I can use Hangouts and Teams without any issues like with Zoom.  Some things I have noticed since trying to track this down:
  • Zoom client has created 4 flows for 1 Zoom call.  I don't think this is normal, and may be a side effect of the dropping issue
show security flow session destination-port 8801 Session ID: 167503915625, Policy name: trust-to-untrust/5, Timeout: 24, Session State: Valid In: 192.168.0.27/57932 --> 144.195.35.200/8801;udp, Conn Tag: 0x0, If: ae0.3, Pkts: 973, Bytes: 119980, Out: 144.195.35.200/8801 --> x.x.x.x/21336;udp, Conn Tag: 0x0, If: pp0.0, Pkts: 101537, Bytes: 31256905, Session ID: 167503917921, Policy name: trust-to-untrust/5, Timeout: 24, Session State: Valid In: 192.168.0.27/65355 --> 144.195.35.200/8801;udp, Conn Tag: 0x0, If: ae0.3, Pkts: 953, Bytes: 117362, Out: 144.195.35.200/8801 --> x.x.x.x/24698;udp, Conn Tag: 0x0, If: pp0.0, Pkts: 952, Bytes: 108550, Session ID: 167503918701, Policy name: trust-to-untrust/5, Timeout: 24, Session State: Valid In: 192.168.0.27/63968 --> 144.195.35.200/8801;udp, Conn Tag: 0x0, If: ae0.3, Pkts: 953, Bytes: 117359, Out: 144.195.35.200/8801 --> x.x.x.x/21022;udp, Conn Tag: 0x0, If: pp0.0, Pkts: 952, Bytes: 108547, Session ID: 167503920196, Policy name: trust-to-untrust/5, Timeout: 24, Session State: Valid In: 192.168.0.27/51674 --> 144.195.35.200/8801;udp, Conn Tag: 0x0, If: ae0.3, Pkts: 48911, Bytes: 28251944, Out: 144.195.35.200/8801 --> x.x.x.x/4207;udp, Conn Tag: 0x0, If: pp0.0, Pkts: 112652, Bytes: 88112545, Total sessions: 4
Routing seems to be okay as well
inet.0: 52 destinations, 52 routes (52 active, 0 holddown, 0 hidden) 192.168.0.27/32 (1 entry, 0 announced) *Access-internal Preference: 12 Next hop type: Router, Next hop index: 0 Address: 0x4cd8d34 Next-hop reference count: 30, Next-hop session id: 0 Kernel Table Id: 0 Next hop: 192.168.0.1 via ae0.3, selected Session Id: 0 State: <Active NotInstall Int NSR-incapable> Age: 3w4d 2:37:06 Validation State: unverified Task: RPD Unix Domain Server./var/run/rpd_serv.local AS path: I Route-nexthop: Router (0x4cd8d34) 192.168.0.1 Thread: junos-main
No drops in queues and the interface is hardly being used
show interfaces ae0 extensive Physical interface: ae0, Enabled, Physical link is Up Interface index: 129, SNMP ifIndex: 559, Generation: 132 Description: LAG to Arista 720XP Link-level type: Ethernet, MTU: 1518, Speed: 2Gbps, BPDU Error: None, Ethernet-Switching Error: None, MAC-REWRITE Error: None, Loopback: Disabled, Source filtering: Disabled, Flow control: Disabled, Minimum links needed: 1, Minimum bandwidth needed: 1bps Device flags : Present Running Interface flags: SNMP-Traps Internal: 0x0 Current address: 12:39:e9:59:3b:a3, Hardware address: 12:39:e9:59:3b:a3 Last flapped : 2025-09-16 12:49:14 MDT (2w6d 01:36 ago) Statistics last cleared: Never Traffic statistics: Input bytes : 63064012289 130904 bps Output bytes : 929159615281 104536 bps Input packets: 246368883 91 pps Output packets: 762012547 50 pps Dropped traffic statistics due to STP State: Input bytes : 0 Output bytes : 0 Input packets: 0 Output packets: 0 Input errors: Errors: 0, Drops: 0, Framing errors: 0, Runts: 0, Giants: 0, Policed discards: 0, Resource errors: 0 Output errors: Carrier transitions: 17, Errors: 0, Drops: 0, MTU errors: 0, Resource errors: 0 Ingress queues: 8 supported, 4 in use Queue counters: Queued packets Transmitted packets Dropped packets 0 0 0 0 1 0 0 0 2 0 0 0 3 0 0 0 Egress queues: 8 supported, 4 in use Queue counters: Queued packets Transmitted packets Dropped packets 0 761204716 761204716 0 1 0 0 0 2 0 0 0 3 952646 952646 0
I don't have CPU grpahs, but I don't see any CPU warnings in the logs, etc...  Hoping someone has seen something like this before and can help out.
TIA
Oct 16, 2025 4:09 AM UTC
First make an ethernet connection to bypass wifi issues. Certain firewalls can introduce issues with the multiple encoding/decoding that takes place when using wifi. If that resolves the issue I would recommend using ethernet instead of wifi.
