Issues with audio/video when running simultaneous meetings
having issues with audio/video when running simultaneous meetings, is there any documentation on this? please advise
April 11, 2024
It is not clear HOW you are doing simultaneous meetings. Typically this is only allowed thru a browser and you may need to use different browsers to separate audio and video. I have run up to 4 simultaneous meetings. To do this I use 3 separate computers thru RealVNC. Since each computer has its own volume control the audio can be remotely controlled. Each Zoom instance is then viewed in a separate window on a 65" 4K screen without any issues. However, there are some instructions https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0068522
Bri
Hi @WebMeeting! Did you find @storyhub's reply helpful? If so, please "Accept as solution" 😊
