Issue: Sound bleed between breakout rooms? | Community
  • April 1, 2022
  • 7 replies
  • 125 views
During events, we are having issues where clients in one breakout room can hear sound from a SEPARATE breakout room. Any help here?
Thank you,
JD
    We had exactly the same problem today as well.  We split the participants into four breakout rooms but two of the breakout rooms could hear each other.  We tried to bring one of the affected breakout room participants back into the main Zoom call to see whether that solved the problem but even then we could still hear the other breakout room.  Any help or guidance would be appreciated as we've never experienced this before and this forum post was the only thing I could find about the issue.
    Thanks
    We had the same problem today as well.  We split the participants into four breakout rooms but all of the breakout rooms and the main room could hear voices from only one breakout room. I would appreciate any help on this issue. Thanks
    JD_TASAuthor
    Just happened again this year at our event - any clues?
    We have had a similar issue twice now… participants in multiple breakout rooms, and one room reported hearing the conversation from the main room. I cannot figure this out! A coworker pointed out that both times we had used music earlier when everyone was in the main session. However, it seems if that was a related factor, then all of the beat rooms would have heard the main room conversation, not just one.
    Any help would be greatly appreciated! Thanks in advance!
    My apologies, I meant breakout* room, not beat room. I am typing from my phone.
    were you able to find a solution???
    We have had the same experience multiple times, and once again today.
