Jan 14, 2025 4:28 PM UTC
Installing on Fire Stick
Sorry if in wrong board, can't see one for installation issues.
I can find the app in Amazon Apps, but it says incompatible with my system. I'm assuming this is because I have no mic or camera installed on the TV the stick is plugged into.
But so what? I only want it on the TV for passive meetings, if I need to interact I'll use the iPad instead.
Is there a way around this so I can install onto the Fire Stick?
ExpertswhoJohn
Jan 16, 2025 9:31 PM UTC
hi @DavidSF
I would first check if it is the latest version, as there are older versions of Zoom that are now out of date and don't work.
All the best
John
