Input audio comes and goes | Community
  • August 26, 2021
  • 3 replies
  • 55 views
Hi Everyone,
I'm new here and not fully sure how to navigate, so apologies if I'm posting this discussion in the wrong place. My question is about audio.
Sometimes during a zoom call, the other person suddenly tells me they've stopped hearing me. When I lean in closer to my computer and/or talk more loudly, the problem seems to resolve, and I can usually then lean back again...until the next time it happens!
I've checked the microphone input levels both in my computer settings and in zoom (they are turned up to maximum) and have tested the microphone in a number of ways. Generally it seems to be fine, and to pick up my voice even when I'm sat some distance back from the computer and/or talking quietly.
I've also tried setting the 'suppress background noise' option in zoom to 'low' instead of 'auto', in case it was inadvertently blocking out my voice as background noise. I'm not sure this makes a difference either, and I don't have such an option in my computer settings (I have a MacBook Air).
This doesn't happen all the time or with every call, just occasionally. It doesn't seem to happen with other software such as Skype or Facetime. I'm interested to hear if others have had this issue on zoom (especially if with a MacBook air) and how you may have resolved it.
Thank you in advance for any responses 🙂
    Hey @Darran, thank you for the detail of your issue! Do you have the 'show in-meeting option to enable original sound' enabled? With that being said, it will enable the following:
    • High fidelity music mode
    • Echo canncellation
    • Stereo audio
    Having these options enabled can increase your bandwidth and CPU utilization. Try disabling, or turning original sound 'off'
    I have a problem with the sound part. I am not heard during a meeting when I speak. I use a macbook air with an apple processor. I notice that the other participants hear each other when they talk during a conversation. If the other participants are silent, then I am heard very well. I did not have this situation on another device with windows operating system. What can I do ?
    Respectfully
    Adrian Ciobanu
    Hey @Darran, just checking in on my reply. Was it helpful? If so, GREAT! 🎉
    Don't forget to click the 'Accept As Solution' button next to my reply. 😄
