Mar 7, 2025 8:12 PM UTC
I need to remove virtual background from zoom meeting I tried from more and choose none but its not
I try to remove virtual background from zoom meeting.  From more and choose none but its not working
MGSRAnswer
Mar 17, 2025 4:27 PM UTC
Hello @mLinco! If you're using macOS, it's possible that the background was uploaded directly to your computer instead of through Zoom. Once the meeting starts, a green video icon will appear in the top-right corner of your Mac's menu bar. Click the icon and uncheck 'Background' to remove the virtual background.
Mar 8, 2025 6:51 AM UTC
Hi DrNadine,
If your virtual background is not turning off after selecting “None,” try these steps:
  • Open Zoom Settings and go to Background & Effects
  • Ensure that “I have a green screen” is unchecked
  • Restart your Zoom app and try again
  • If the issue persists, update your Zoom to the latest version
Mar 9, 2025 10:08 PM UTC
hi @DrNadine,
please user instructions in this support article.
Enabling or disabling virtual backgrounds
Mar 14, 2025 3:19 PM UTC
Hi @DrNadine!
Did you see the previous responses?
If it has resolved your inquiry, please press the Accept as Solution.
Have a great day!
Mar 14, 2025 3:43 PM UTC
If none is selected in the Zoom background and effects menu it's very possible that the virtual background is coming from your operating system or some other program.
Regards
Mar 14, 2025 8:16 PM UTC
I believe this is my issue, but I need instructions to fix the problem. Where can I find/delete the image that i uploaded as a background image. When I select NONE in virtual images, the image is still there. HELP
MGSRAnswer
