Oct 5, 2021 2:33 PM UTC
I could not hear my guest and he could not hear me
Hello everyone,
Thank you for the help. First time user.
So I scheduled a meeting and we could see each other. But we could not hear each other.
Do I need to do something? Any advice, please.
We both had earphones.
I was on a desktop and he was on phone. I don't know if that makes a difference.
thanks
ashley
    Rupert
    Oct 5, 2021 4:49 PM UTC
    If the other participant was joined from a cell phone using the Zoom app, they would have likely received a prompt on how to connect to Audio - whether through the app or via a telephone call. They would want to choose app audio (not phone).
    Actually you may also see a similar question at your end even on a desktop - using Computer Audio, or Telephone. You will want to use Computer Audio.
    You will both want to make sure you un-mute yourselves.
    You can also run a test meeting to test your audio devices at  https://zoom.us/test Can you test there?
    Oct 6, 2021 1:18 PM UTC
    Thanks, I am going to try again once he is back home with his laptop and can use headphones. I'll try again. cheers
    Jan 26, 2025 8:14 AM UTC
    I can not hear guests at all. I have tried 4 interviews with different people with the same result , they can not be heard
