Lena Paul
Jun 14, 2026 6:02 PM UTC
How to maintain 320kbps audio quality for Zoom Music Lessons on Android?
Hey community, I'm an online music teacher and I conduct all my practical classes via Zoom meetings. Recently, my students have started complaining that the background tracks I play from Spotify sound very muffled and low-quality due to Zoom's audio compression on Android. On top of that, sudden loud ads during a live lesson are becoming highly embarrassing for me as a professional. Since I use an Android phone for my setup, is there any way to bypass this compression and stream crisp, ad-free music? Are there any specific app modifications or configurations that fellow musicians use here? I am currently trying to troubleshoot this using some audio optimization guides from Soundify  but any direct workaround for Android would be a lifesaver.
Thanks in advance!
Jun 14, 2026 6:51 PM UTC
You can’t force “320 kilobits per second” end‑to‑end through Zoom on Android (or any device, really), but you can get much closer to “crisp enough for lessons” by combining Zoom’s music‑oriented audio settings, perhaps with an external audio path and a separate music source that is already ad‑free. Zoom’s mobile client still applies constraints and compression, so the realistic goal is “transparent enough for teaching” rather than exact Spotify bitrate delivery.
Are you using Original Sound settings? This week bypass noise suppression and voice prioritization. Tap the screen and look for a toggle like Original sound: Off; tap it so it reads Original sound: On.
The Zoom app can’t really help you with the Ads issue. The Original Sound might help, but if there’s a significant volume difference when the ad plays, you're really stuck with the audio chain available on Android.
Ray Harwood | GoodClix | Event Producer
Community Super Champion | Zoom MVP
Lena Paul
Lena PaulAuthor
Jun 14, 2026 7:25 PM UTC
Hi Ray, thank you so much for the detailed and realistic breakdown! I didn't realize Zoom's mobile client caps the bitrate that heavily regardless of the source. I will definitely toggle the 'Original Sound' setting ON before my next class to bypass the noise suppression; that should at least help with the instrument clarity.
You're spot on about the ads; the sudden volume jump is what makes it so awkward during a live lesson. Since Zoom can't help with that, I suppose I'll have to look into some device-side custom audio setups or modified players that can handle ad-blocking on Android. Truly appreciate your expert advice!
Jun 15, 2026 4:55 AM UTC
Zoom is designed for voice communication, so some audio compression is unavoidable, especially on mobile devices. For music lessons, a few legitimate options can help improve quality:
  • Enable Original Sound for Musicians (if available on your Zoom account and device).
  • Use Share Sound when sharing audio rather than playing it through your phone's speakers and microphone.
  • Ask students to enable high-quality audio settings on their end as well.
  • Consider using a paid, ad-free music service to avoid interruptions during lessons.
  • If possible, run Zoom from a computer instead of Android, as desktop Zoom offers more advanced audio controls for music.
As for app modifications or unofficial Spotify/Zoom tweaks to bypass ads or compression, I wouldn't recommend them. They can violate terms of service, create security risks, and often lead to unstable performance.
For the best results, many online music teachers use a laptop with Zoom's music settings enabled and feed audio directly into the meeting rather than relying on phone playback.
