Sep 29, 2022 2:59 PM UTC
How to hide "Floating Control Settings Panel" on Facebook Portal TV LW94NS
I have recently bought a new Facebook Portal TV. But can't find how to hide Floating Control Settings Panel while sharing screen is enabled. (video attached)
That panel works great if no one is using screen sharing, it automatically hides, but if someone starts to share, panel keeps floating there.
I was testing and just using "gallery" view layout works, the others just don't.
Any solution?
Thanks.
    Nov 19, 2022 8:29 PM UTC
    Did this ever get sorted?  I'd like to know the same thing.  It's the single most annoying thing about Zoom on Meta Portal, the annoying floating controls remaining on the screen and blocking the shared content. We need the option to always hide unless we use the remote to show the controls.
    Nov 23, 2022 3:34 PM UTC
    This problem persists, there is not an update yet... Hope this will be solved soon, I think is so basic, I mean, we are talking about Facebook and Zoom xD
