How to Fix Error Code 1142
My Friend from Singapore could not join my  meeting which hosted in Thailand, Instead, there is the Error Code 1142.
However, she can join other meetings hosted in Thailand. Only me that she could not join, Is there any way to fix this problem ?
I found that
The code 1142 : indicated you are trying to join the meeting from the country might be blocked by Zoom, This can also appear if you are using proxy that is set to a country that has been blocked by the Zoom.
If so, How to solve it, please?
    Rupert
    RupertAnswer
    Hi @May1211
    I would check your account for any "Approve or block entry for users from specific countries/regions" settings under https://zoom.us/profile/setting
    You can also check the same setting for your actual meeting itself under:
    https://zoom.us/meeting > Edit
    Finally, you could check your Transit Data settings - but I I'm not sure that would be the problem. https://zoom.us/profile
    Rupert
    RupertAnswer
    Hi @May1211
    I had the  same problem but it was blocking myself out so i cant start my own meeting.but when i went to the profile settings it was blocked by admin.but whos admin?
    idid try all three things you mentioned
    我也遇到相同的問題
    無法加入會議
    目前無法從澳大利亞存取此會議。(錯誤代碼:1142)
    Same problem here. I have done every possible setting from suggestions, but all didn't work for me. I request Zoom to fix this issue 2 times already, but it seems no action.
