How to enable audio transcripts for cloud recordings on a pro account
Prerequisites for enabling and creating audio transcripts for Zoom cloud recordings
  • A Pro, Business, Education, or Enterprise account with cloud recording enabled
    I have a pro account, I've recorded on cloud, and I can't see the option to generate audio transcript?
    I want to send across to a hard of hearing client, and captions are needed or audio transcript.
Hey, how did you enabled cloud recording. even i enabled it from settings, any audio or video did not saved to cloud
TAH2024Author
honestly, i have no idea how i did it. lol I really just want to know about the next part now!
Firas_ghobber
Community Champion | Partner
April 25, 2024
Hello ,
Please follow those steps and try to record meetign and check it in Zoom web portal.
reference : Managing and sharing cloud recordings (zoom.com)
Managing cloud recording settings (zoom.com)
Best regards,
Firas
TAH2024Author
i just clicked on 'create audio transcript' (screenshot shows this) and then the other screenshots were what it was set as. can i still pull the transcript even though its after the recording?
Firas_ghobber
April 25, 2024
Yes you can pull the transcript after recording and you can also save the transcript during the meeting in local pc .
Best regards,
Firas
TAH2024Author
where? because I don't see it as an option in recordings. only txt file of what is in chat box and not the actual recording.
Firas_ghobber
April 26, 2024
Following your request, you have confirmed that all prerequisites for Zoom recording transcripts are available. You conducted a test recording session and discussed it in the meeting, but the transcript did not appear in the recording management.
Therefore, I recommend submit a request  to Zoom Support to have this feature enabled.
Best regards,
Firas
