Jan 16, 2025 8:41 AM UTC
How to disable the annoying notification in meetings : "Not hearing anything? Turn up volume" ?
I want to disable this useless option, as the huge majority knows obviously how to manage the volume on their computers.
Where is the option ?
ExpertswhoJohn
Jan 16, 2025 9:47 PM UTC
Hi @v01dv01d ,
There are two sides to this, and we can not please both. Those that want to know and those that don't.
I would consider myself a power expert on Zoom, yet I have turned down the volume before and then missed something. On balance, zoom thinks it is better to warn people.
hope you understand
John
hope you understand
John
v01dv01dAuthor
Jan 17, 2025 8:10 AM UTC
Thanks for the quick answer.
You can still please the "other side" by adding an option to disable such a notification.
That's not hard and you know it.
Although I understand the fact that sometimes there can be something off and the notification is useful.
But 90% of the time, for me, it is not.
Golden rule of UI features : if you add a new behaviour, add an option to disable it.
Hope you understand. Hope the devs/POs would understand.
That wouldn't cost so many "effort points" or whatever they call it.
v01d
