Dec 30, 2021 1:08 PM UTC
How to Connect Bluetooth speaker with zoom?
No text available
    Apr 19, 2023 5:14 AM UTC
    Sign in to the Zoom web portal.
    In the navigation panel, click Settings.
    Click the Meeting tab.
    Under In Meeting (Advanced), verify that Allow users to select stereo audio in their client settings is enabled.
    If the setting is disabled, click the toggle to enable it.
    Regards,
    Will
    Apr 24, 2023 7:12 PM UTC
    I checked and I already had this option enabled
    Jun 28, 2023 10:25 AM UTC
    So I just had this issue after a phone update and found the problem to be a permission issue. Checking the Zoom app permissions on my Pixel 6, it revealed that the "Nearby devices permission" were set to "Don't allow", switched it to "Allow" and Zoom worked with my headset again. The fun thing is that it works with everything else, so I guess zoom is doing something special that requires extra permissions, but that they don't check that the app actually have that permission - I would expect 99% of users of the android app would be using a BT device, so if that permission isn't there, the app should give out a warning about it and not waste so many peoples time...
    Jun 28, 2023 3:20 PM UTC
    Omigosh, if this fixes it, it would be AMAZING!!! Mine was unchecked, so I turned it on and I'll report back. THANK YOU!
    Jul 7, 2023 10:49 PM UTC
    update: this didn't fix it for me. 😞 on top of that, when i deleted the data option in storage, like i normally had to do in order to get it to work, it toggles this option back off everytime. ARGHHHH
    Jul 6, 2023 5:16 PM UTC
    Hello All,
    I have had the same issue as many here have.
    SOLVED it by granting android permission Nearby devices to zoom app.
    Have a nice day.
    Sep 27, 2023 12:53 AM UTC
    This worked for me. Thanks for helping me finally fix this!
    Jul 18, 2023 5:33 AM UTC
    I'm having same problem. Zoom does not give an option to play audio to my bluetooth headphones. The speaker icon only toggles between mute and not muted. But, I can use the bluetooth headphones with both Whatsapp voice calling and entertainment apps such as Youtube and Netflix. I'm thinking the issue stems from these being headphones only, and not a full headset with both mic and headphones. Zoom doesn't seem to like the idea of using the phone's mic while using the bluetooth speaker/headphone
    Nov 29, 2023 2:35 PM UTC
    Fix - Enable Nearby devices permission for zoom in Android
    Mar 5, 2024 7:37 PM UTC
    Hello @SaraKarolina,
    To connect your Bluetooth speaker to the Zoom desktop client, follow these steps:
    1. Open the Zoom desktop client.
    2. Go to Settings.
    3. Navigate to the Audio section.
    4. Check that your Bluetooth speaker is available and connected under both Microphone and Speaker output settings.
    5. Ensure that the Bluetooth speaker remains connected during your meetings for seamless audio output.
    Thanks
    Btw the moon is beautiful isn't it response.
    Oct 5, 2024 4:52 AM UTC
    To connect a Bluetooth speaker to Zoom, pair the speaker with your device, set it as the default audio output, and select it in Zoom's audio settings.
