Apr 26, 2023 7:10 PM UTC
how do i turn off participants join sound (doorbell) when i'm not host or co-host?
i found it's very disturbing to me when i need to listen to it hundreds of times in big meetings.
    Oct 27, 2025 5:24 PM UTC
    Assuming you have write access to the zoom installation directory on your computer (on my linux install, it's under /opt/zoom/), you can delete the files dingdong.pcm and dingdong1.pcm. This finally killed the doorbell sound for me.
    For good measure, I also deleted mute.pcm and unmute.pcm, which apparently are responsible for the new mute/unmute sound effects that zoom has apparently decided are mandatory as well.
    And just to affirm what others have said, these sounds *used* to be optional. But Zoom apparently decided that everyone needs to be blasted with them involuntarily. It has made many meetings impossible to meaningfully participate in.
    Oct 27, 2025 5:43 PM UTC
    Thank you singlephoton! Located them under C:\Users\yournamehere\AppData\Roaming\Zoom\bin
    I ended up just renaming the extension incase anything funky happens on my next meeting.
    Feb 7, 2026 5:29 PM UTC
    Are you serious Zoom? Why is this still an issue? Why do we all need to hear these dings? Please for the love of god allow us to turn these dings off. They drive me up the wall. So much so that i want to chuck my computer against the wall.
    New Member
    Oct 28, 2026 11:17 PM UTC
    Still not a feature that has been reenabled in Oct (almost Nov!) 2026. AI recordings? Sure! Don't want to hear *dingdong* every 30 seconds? Nope. I understand only wanting the host to have certain meeting-specific settings, but if you’re a student or trainee and are trying to hear an announcement near the beginning or end of the session, it’s incredibly frustrating to have a non-volume normalized sound effect play as people join/leaves. Why should I expect my trainer to know where to find the setting to allow only them as the host to hear this?
    Thanks to the earlier user ​@singlephoton for their solution.
