How do i stop up professional audio settings prompt?
How do i stop the zoom message "set up professional audio in audio settings" from appearing on the desktop mac version of Zoom?
Frequently when rebooting the laptop I get asked this.  Annoying.
yes this is a huge problem
I am having the same issue, and since I record my fitness classes with "screen record," it's ruining my videos. Can't get any answers from Zoom support
Fit-Cut-Pro
Hello online fitness trainer,
I'm going to try and help you. First, let me recommend you of our special workout timer and overlays Zoom app which was just release and might really upgrade your fitness classes - you can get it here:
https://marketplace.zoom.us/apps/4cApKG12TJW21YzHCn3sYw
Secondly, try those steps for your problem:
To prevent the recurring "Set up professional audio in audio settings" prompt in Zoom on your Mac, you can adjust your audio settings as follows:
  1. Open Zoom Settings:
    • Launch the Zoom application.
    • Click on your profile picture in the top-right corner.
    • Select "Settings" from the dropdown menu.
  2. Navigate to Audio Settings:
    • In the Settings window, click on the "Audio" tab.
  3. Adjust Background Noise Suppression:
    • Under the "Audio Profile" section, ensure that "Zoom optimized audio" is selected.
    • Set the "Background noise suppression" level to your preference (e.g., "Auto" or "Low").
  4. Disable Original Sound for Musicians:
    • If "Original sound for musicians" is enabled, consider disabling it unless you specifically need it for high-fidelity audio purposes.
      Feel free to contact *********** if you have any issue with our zoom app.
      Good luck!
Fit-Cut-Pro
Hi, if you do fitness classes, you might be interested in our Zoom app: https://marketplace.zoom.us/apps/4cApKG12TJW21YzHCn3sYw
For you issue, you can try and use these steps:
Hello there,
Welcome to the Zoom Community!
We apologize for the inconvenience. Before joining a meeting, please go to your settings > Audio > Original Sound for Musicians and select one of the available options. If you don't plan to use the "Original Sound for Musicians" feature, you can choose the Zoom Background Noise Removal option after enabling Original Sound for Musicians.
