Sep 30, 2025 3:27 PM UTC
How do I prevent Zoom from resetting my input volume to 1/4 on launch?
Zoom always resets my microphone input volume to about 1/4 of the maximum volume when I launch it. This means people in meetings can't hear me properly until I remember this silliness has happened and go to settings to increase my microphone input volume. I'm getting tired of this behaviour. Is there a way to make Zoom remember the last input volume (or a preselected input volume)?
Thanks in advance for any help.
Oct 1, 2025 4:27 PM UTC
Is it possibly the Zoom mic setting?
Zoom app settings > Audio > Microphone
Oct 1, 2025 4:30 PM UTC
Yes, that's precisely my point. That slider is always reset to 1/4 of the maximum value. I always have to manually set it to the maximum value for people to hear me properly. Is there a way to set it to the maximum by default?
Oct 1, 2025 5:11 PM UTC
I am not sure I can try and look though settings. Are you on Apple or Windows?
Would turning off the "Automatically adjust the microphone volume" fix the issue?
Jan 8, 2026 4:59 PM UTC
Having a similar issue.  Also on a Mac.  Also have mic set to 100% in the Mac OS.
Using OBS to craft my vocal (and video) experience in Zoom calls.
Zoom keeps reducing my Microphone Input - all the settings are happening elsewhere, and Zoom then makes me sound too soft.
See attached for Zoom settings - everything sticks EXCEPT the Microphone Input volume.
Thanks for any suggestions - David
Jan 30, 2026 2:32 PM UTC
Hey everyone - since the community was “read only” for a bit, I’m replying to bump this up.
If anyone found a solution to this, please let me know.  Not only can I confirm it constantly happens, I have been meeting regularly with someone on the other side of the planet (12 hour time zone difference) who experiences the same thing. So it’s world-wide. 😁.
Feb 3, 2026 8:59 PM UTC
I have the same issue. I keep having people on my calls tell me I am quiet. I look in the settings, and despite auto-adjust being off, Zoom keeps resetting my input volume to 45%. Has anyone identified a fix?
Feb 3, 2026 9:09 PM UTC
I’m still working through this.  I’ve recently seen the same issue around other meeting tools on Chrome; possibly related… Finally found that the Apple System Settings | Sound | Input for my device is also changing (had not noticed that before; either it wasn’t changing, or I simply caught it at not the best time).
Suggestion via an AI generated search summary below.  I've tried 1 part 1 and am trying 1 part 2 now; suggestion 2 will be next.  Also note the MacBook Air M1/M2 caveat (not my device, but in case it’s yours) :
Input volume changing on its own on a Mac is typically caused by application-level auto-gain control (like in Zoom, Meet, or Skype) or macOS trying to manage gain on a virtual device. Because BlackHole is a virtual driver, it often adopts the behaviors of the applications using it.
Here are the most common causes and solutions based on user reports:
1. Disable Auto-Adjust in Conferencing Apps
Applications like Zoom, Skype, or Chrome (for Google Meet) often have built-in "Automatic Microphone Adjustment" settings that override system settings.
• Zoom: Go to Settings > Audio and uncheck "Automatically adjust microphone volume".
• Google Meet/Chrome: If the issue happens in Chrome, it may be due to WebRTC. You can try disabling this via chrome://flags by searching for "Allow WebRTC to adjust the input volume" and setting it to disabled.
2. Use an Aggregate Device (Best Solution)
If you are using BlackHole alongside a microphone to record, the input volume might be unstable.
1. Open Audio MIDI Setup.
2. Click the + button in the bottom left and select Create Aggregate Device.
3. Check the boxes for your microphone and BlackHole 2ch.
4. Use this new "Aggregate Device" as your input in recording software (OBS, QuickTime). This often locks the input volume because it combines the devices.
4. Other Potential Fixes
• Reboot: A simple reboot can sometimes reset the audio driver behavior.
• Set Output to 95-100%: Some users find that keeping the output volume at a high, consistent level (around 95%) keeps the virtual driver stable.
• Check for conflicting audio software: Ensure other audio tools aren't fighting for control over the input level.
Note: If you are experiencing this specifically with a MacBook Air M1/M2, it is a known behavior where the system limits the volume to prevent audio distortion.
AI responses may include mistakes.
Apr 20, 2026 2:39 PM UTC
I appreciate the previous answer -- but I wonder if it’s clear that this is not happening in other apps for me (if it is for you, could you describe the apps and exactly what’s happening that’s similar?)
It seemed to correlate with a fairly recent Zoom Update in which the Zoom interface also made it much more difficult to switch from Original Sound to the standard audio setting - and while those two issues may not be directly related they did seem to happen at exactly the same time.
It also sounds like several of us on this thread are experiencing this are longtime users of Zoom and have substantial experience with online audio - and the one thing that changed here was Zoom.
So could the folks at Zoom who made the most recent changes to how Original Sound is selected please check to see if there were other changes you made that may be creating this problem for many of us?
New Member
Aug 2, 2026 11:15 PM UTC
My issue is the same on my H5 Studio. Connecting a mic , I get the message INPUT OVERLOAD.  Then NO audio.  Looking for solutions here too.
Aug 28, 2026 9:18 PM UTC
Hello ​@AUDIOMAC,
I’m sorry for the late response. I can help with the Zoom app side (audio device selection and input levels), but “H5 Studio INPUT OVERLOAD” is coming from the recorder/interface itself (hardware gain/input clipping), not a Zoom-specific message.
Try these Zoom-focused checks:
  1. Select the correct mic in Zoom
  • Zoom app → Settings → Audio
  • Under Microphone, choose the H5 (it may appear as "H5," “Zoom H5," or “USB Audio Device”)
  • Click Test Mic and watch the input level meter
  1. Turn off Zoom’s automatic mic level and set it manually
  • In the same Audio settings page, disable “Automatically adjust microphone volume."
  • Set the input slider low, then raise it gradually while speaking
  1. Confirm the H5 is actually sending audio to the computer
  • In Zoom Audio settings, make sure the mic meter moves at all
  • If it never moves, the issue is likely the H5 USB mode/routing or the input level on the H5 (hardware)
To narrow it down to the right fix, which connection are you using with the H5: USB into your computer as an audio interface, or analog (3.5mm) into the computer
