How do I fix Zoom Meeting audio and video issues? | Community
New Member
June 13, 2026
  • June 13, 2026
  • 3 replies
  • 579 views
If you are facing audio and video issues in Zoom Meetings, the problem is usually related to device settings, permissions, internet connection, or outdated software.
First, check your microphone and camera permissions. Make sure Zoom has access to your device’s microphone and camera in system settings.
For audio issues, ensure the correct speaker and microphone are selected inside Zoom settings. Test your audio before joining a meeting and unmute yourself if needed. If there is no sound, try plugging in headphones or restarting the app.
For video issues, verify that the correct camera is selected and not being used by another application. Restarting your camera or switching to a different device can help resolve the issue.
A weak or unstable internet connection can also cause lag, freezing, or poor audio/video quality. Switching to a stable Wi-Fi network or using a wired connection improves performance.
Also, make sure your Zoom app is updated to the latest version, as outdated versions often cause compatibility issues.
In most cases, Zoom audio and video problems can be fixed by checking permissions, selecting the correct devices, improving internet stability, and updating the application.
ExpertswhoJohn
June 15, 2026
hi ​@markolivia ,
Thank you for a helpful post, but sneaking your web address for some SEO is not appreciated.
John
If you're experiencing audio or video problems in Zoom Meetings, there are several simple troubleshooting steps that can resolve most issues.
  • Check permissions: Ensure Zoom has permission to access your microphone and camera in your device's privacy settings.
  • Verify audio settings: In Zoom, confirm that the correct microphone and speaker are selected. Use the built-in audio test before joining a meeting.
  • Check video settings: Make sure the correct camera is selected and that no other application is using it.
  • Restart Zoom and your device: A quick restart often fixes temporary glitches.
  • Improve your internet connection: Use a stable Wi-Fi network or, if possible, a wired connection to reduce lag and freezing.
  • Update Zoom: Running the latest version helps prevent compatibility and performance issues.
  • Close unnecessary applications: Other programs may consume bandwidth or interfere with your camera and microphone.
In most cases, checking device permissions, selecting the correct audio/video devices, improving internet stability, and keeping Zoom updated will resolve the problem. If issues persist, try joining the meeting from another device to determine whether the problem is device-specific.
