Nov 29, 2023 9:32 AM UTC
How can I disable the notification "Not hearing anything? Turn up volume"?
This notification started appearing after I updated Zoom for Windows to version 5.16.10 and appears when the computer's volume is equal to or less than 10%.
I couldn't find the option to disable this alert in the Accessibility menu.
ExpertswhoJohn
Dec 4, 2023 10:36 PM UTC
hi @once
This option can not be disabled at present.
It was added recently because of low volume problems of users.
all the best
John
Oct 20, 2025 1:30 PM UTC
It happened again..... I am getting HEARING DAMAGE from this application. I will be contacting the national consumer protection authorities to investigate this as a potential health hazard.
Oct 22, 2025 6:00 PM UTC
I'm looking for alternatives to Zoom, since the company chooses not to hear their customers.
It's an absurd, having to click that every time.
Dec 11, 2025 7:19 PM UTC
Bad software engineers.  Just add a disable option.  You fixed problem for a small number of users in exchange for causing a problem for the masses.   Have some situational awareness and open your minds.
May 26, 2026 1:12 AM UTC
PLease add a disable option. Just do it!
New Member
Oct 20, 2026 3:47 AM UTC
It’s very annoying for deaf people, including me, and it makes us click more to close it. It’s audism.
