How can I disable the notification "Not hearing anything? Turn up volume"? | Community
  • November 29, 2023
  • 42 replies
  • 568 views
This notification started appearing after I updated Zoom for Windows to version 5.16.10 and appears when the computer's volume is equal to or less than 10%.
I couldn't find the option to disable this alert in the Accessibility menu.
Best answer by ExpertswhoJohn
hi @once
This option can not be disabled at present.
It was added recently because of low volume problems of users.
all the best
John
ExpertswhoJohn
December 4, 2023
hi @once
all the best
John
This is a crap answer.  My volume works just fine.  Zoom needs to give people the option of turning that off permanently
Exactly, throw it under an accessibility feature for 'warning when system volume low' and let me turn it off.
I get the prompt at 50% system volume when using my headset. version 5.16.10
This needs to be removed or at least allow us to disable the pop up. My volume is fine. I accidentally clicked it and it immediately raised the volume to a painful level.
I did this, too, and learned the lesson. The lowest volume is actually a little too loud in my headphones and I use a third-party program trim that down 30%.
I'm having this same issue. The annoying "Not hearing anything?" popup appears at the beginning of every meeting even though my volume/sound is always fine (and hasn't changed recently).
At the very least, have the popup disappear after a few seconds. I shouldn't have to manually close it every time.
This is on Zoom desktop 5.16.10 for Windows. Thanks.
I second this - it should be possible to disable this feature since it is annoyingly catching my attention during each meeting while the volume is perfectly OK.
Please allow users to disable this "feature".
This needs to be a "feature" we can turn off!
CarlaA
Hi everyone! Thank you all for your feedback on this topic.
As @ExpertswhoJohn mentioned above, there is currently no way to disable this pop-up. However, I would highly  encourage you to submit this feedback via the steps outlined here: Sending feedback to Zoom.
Our product teams review all feedback submitted via this form. Thank you and apologies for any inconvenience this may be causing you at the moment.
Is there a minimum volume that it needs to be set at to stop it showing?
Someone said if the volume is below 10% it'll show. Well my volume is currently on 60% and it's still showing!
I have external speakers, which I can adjust the volume on. So I can set them to super low, while turning up Windows' volume. But it still always seems to pop up.
It's not the end of the world, but it's an irritation to constantly see it whenever I start a call.
Bumping this topic to make is visible to the dev team / POs.
Golden rule of apps : for each feature, give an option to hide it or disable it.
Thank you !
I agree. This feature is so annoying. My volume is always fine. There are other annoying pop-ups that I want to turn off too, like when I share my screen there's this little square which pops out from under the tool bar.
Hello. Could you please contact development support and put in a request for this feature. Sometimes I screen record when I'm not there, then the entire Zoom meeting has a "Not hearing anything? Turn up volume"?
Please acknowledge. Thank you.
ExpertswhoJohn
February 11, 2025
HI@bradsmithsite  and others
I suggest you put your own request so the dev team can see more requirests.
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0068808
John
Thank you.
