Mar 12, 2026 8:41 PM UTC
Hot Key for Noise Removal & Original Sound
Is there a hot key combo for switching between Noise Removal and Original sound for musicians? Ever since the button was removed from the top left I find it increasingly difficult to switch between the two quickly.
We do government training classes via Webinar on Zoom Gov. We run the default Noise Removal mode most is the time but when we have a PowerPoint video our audio or maybe someone in the live audience is asking a question, we switch to Original sound. Clicking on that tiny up arrow on the Audio button and selecting between the two is challenging to do quickly under pressure. If there isn't a hot key, I'm begging for one.
    ExpertswhoJohn
    Mar 12, 2026 11:16 PM UTC
    hi ​@Josh Money
    yes a lot of poeple are asking for this. I am trying to get an app released to help, but getting all the permisssion takes time.Please like and mark as the solution if this helps
    All the best
    John Drinkwater
    Zoom Developer Champion
    https://lordzoom.com/go/hub
    tom cary
    Contributor I
    Contributor I
    Mar 13, 2026 1:12 AM UTC
    That’s a great question. I’ve run into the same challenge since the quick toggle was removed from the top left. Switching between Noise Removal and Original Sound through the audio menu can be tricky during live sessions, especially in webinars where timing matters.
    As far as I know, Zoom currently doesn’t offer a dedicated hotkey for this toggle, but it would definitely be a helpful feature. Hopefully the team considers adding a shortcut or bringing back a quicker toggle option
    Mar 14, 2026 5:45 AM UTC
    Enabling echo cancellation under original sound can help. Personally as an audio engineer I have original sound locked on via registry and control noise acoustically and with a dynamic mic that does not pickup environmental noise. So I don’t miss the toggle and find that vocal quality heard by the participants is superior to using Zoom’s noise cancellation. You can also use other software such as OBS Studio to do noise reduction that can easily be switched on and off.
