Help re how to add an alterative host for a daily group when i am on holiday. is is free? | Community
  • March 21, 2022
  • 31 views
No text available
    @annemarie The below article will help show you the steps for adding an alternative host.
    You will only be able to designate an alternative host if the user is 1) on the same account as yourself and 2) is also licensed.
    If the above conditions are not met, then you would need to start the meeting and then assign a host at the beginning to the needed user before leaving the meeting.
    Designating-an-alternative-host
    If this answer helped solve your question/issue, please hit the "Accept as Solution" button below.
