Feb 10, 2022 8:31 PM UTC
Help: Not recording the active speaker
When I record meetings, Zoom is only recording the video of the person who has joined the meeting, not my video. It used to switch back and forth depending on the active speaker, but now that has changed. I'm a coach and having both sides of the conversation is essential for my business. It will record both videos in Gallery Mode, but not Speaker Mode.
I have tried "See myself as active speaker," but that's an untenable solution. I need to see my client's facial expression while I am speaking to do my job, and it's very jarring/unpleasant to see myself speaking.
Is this happening to anyone else? is there a known fix for it? If I don't get this fixed, I'll have to leave Zoom and find another solution because this is an essential part of my business.
Feb 11, 2022 10:14 AM UTC
Check your Recording settings via your Zoom portal in Account Settings, Recording. Check if Record active speaker with shared screen is enabled. You can select multiple options too; Record active speaker, gallery view and shared screen separately is very useful if you want to compose a training video yourself afterwards. You can even Record a separate audio file of each participant if you want.
dvscarrAuthor
Feb 11, 2022 1:18 PM UTC
Unfortunately, those solutions aren't relevant to my situation. I already have Record active speaker with shared screen enabled. My problem is how it records the video when my screen is NOT shared. I do not want separate video files of the active speaker, gallery view, etc., as I do not want to create a training video after. Recording separate audio files also doesn't help me either. I need to be able to record both my client AND myself in the sessions.
Feb 11, 2022 3:01 PM UTC
I don't have a solution yet, but I wanted to express my solidarity in frustration! I've recorded hundreds of zoom meetings in the last nine months, and last night for the first time, the recording only recorded my guest's video, not mine. Extremely irritating to say the least. I don't have a solution yet, but I wanted to express my solidarity in frustration! I've recorded hundreds of zoom meetings in the last nine months, and last night for the first time, the recording only recorded my guest's video, not mine. Extremely irritating to say the least.
Feb 15, 2022 3:55 PM UTC
I am having the same issue.
dvscarrAuthor
Feb 16, 2022 8:41 PM UTC
Someone on Twitter suggested going back to a previous version of Zoom. They downgraded to 5.8.6 (2879) and said that it works. I haven't tested it yet but will report back on how it goes.
Pretty terrible to have to go down several versions just to regain essential functionality. I'm so frustrated with Zoom and am looking for alternatives. What's the point in paying hundreds of dollars when it can't do the one thing I need?!
Mar 31, 2022 2:04 AM UTC
I have to say, it's relieving to see that others are having a similar issue.  I take guitar lessons over Zoom and sometimes record my teacher playing passages.  Typically, I mute myself and then start the video, and it defaults to recording him, as he's the active speaker.  Recently, it records me being quiet and watching him, which is obviously of no use.  This has now happened with two subsequent lessons.  One would think that Zoom would have figured this out by now...
Thanks for sharing the workaround of downgrading; I'll try finding the previous version.
Mar 14, 2022 9:32 PM UTC
I am having the same issue. Zoom support is telling me its because of my wifi which is actually fine and the same speeds it always is. I have no issues with video or audio quality in the call.
Here is their response:
Zoom is pretty much unusable if it doesnt record switching the active speaker back and forth.
If anyone has any result where it works I would love to hear too. Thanks for posting this and zoom I hope you are listening and can help return it to how it used to work!
Mar 31, 2022 2:05 AM UTC
I'm not seeing Zoom's response, only a clip from a previous posting.
Mar 15, 2022 5:58 PM UTC
This just happened to me, too. VERY frustrating. Has anyone managed to resolve this issue or get clarification from Zoom about what's going on here?
Mar 31, 2022 2:36 AM UTC
It appears as though this was fixed in version 5.10.0 (5714),  a couple of weeks ago:
  • "Resolved an issue regarding local recordings not capturing speaker view"
I have Zoom set to auto-update, which, of course, it had not.
Apr 7, 2022 6:47 AM UTC
Well,  after my update, I am still having the same problem.  Any ideas?
Thanks,
Allan
May 1, 2022 6:56 PM UTC
I am having the same problem. Sometimes it records just me and sometimes it records a guest. No one is spotlighted.
Aug 9, 2022 6:58 PM UTC
Same with me.  My only solution takes a long time - work with gallery and edit screen shots in Premiere to stay fixed on the speaker during the time of speaking.  Manual operation takes about the same length of time as the recording.
