Help: local recordings not showing host video in speaker view
For the past month or so my local recordings of 1on1 meetings in Speaker View only show the guest's video but not the host's (i.e. mine). Both audio streams work fine, but the video stays fixed on the guest. I haven't pinned videos or anything. I don't have this issue with cloud recordings.  Is this a bug or do I have something set wrong?
Alex_PFT
Partner
Partner
February 7, 2022
The recording should show the active speaker. See this for all possible layouts:
Recording layouts – Zoom Support
Participant
February 8, 2022
I've noticed the same thing.  Have you found a solution?
Alex_PFT
Partner
Partner
February 8, 2022
This might help?
Participant
February 8, 2022
Thanks, but I already saw that page.  It doesn't answer the question.
I am having this exact issue and it's a huge problem for my business. I can record both screens in gallery mode, but now instead of switching back and forth between Active Speakers, it just records the guest. I'm a counsellor and "See myself as active viewer" makes Zoom unusable for me because it means I can't see my client's facial expressions while I'm talking.
I have the exact same problem but have found that when I have three or more people on the problem doesn't exist.  Does everyone find the same?
Participant
February 11, 2022
Yes, that's what we discovered.
Hello
I'm a piano teacher and I'm having the same problem in the last 2 weeks.
I didn't change anything. Same settings on zoom, same mic, same cables, same webcam, same OS, same apps... Everything like the past 2 years and suddenly my local recordings don't show me anymore teaching... just my student watching me...and my sound..
I "solved" the problem for now changing to gallery view, but it's not good for my students because the piano image on recording it's half the ideal size..
Please let me know if you fix this problem
Thank you
I've just installed de last update Version: 5.9.3 (4239)
I've tried and the problem is still happening...not solved
Someone on Twitter suggested going back to a previous version of Zoom. They downgraded to 5.8.6 (2879) and said that it works. I haven't tested it yet but will report back on how it goes.
Pretty terrible to have to go down several versions just to regain essential functionality. I'm so frustrated with Zoom and am looking for alternatives. What's the point in paying hundreds of dollars when it can't do the one thing I need?!
How do we do that?
In the meantime while we're waiting for a fix, you should try recording to the cloud. This method has worked for me. It's just that I want it to work for recording directly to my computer like it used to.
Experiencing the exact same problem. I bought a new laptop and since then it only records the guest. When using my old laptop it works fine. I'm stating the same as everyone else but hoping by bumping this message it adds a bit more weight of importance so the problem is addressed.
Interesting. Are you running the same version of Zoom on both computers?  Mac or PC?
¡¡Hola!! Estoy aquí exactamente con el mismo problema. Puedo ver a mis clientes en la grabación, pero nada sobre mi cámara. Mis clientes necesitan verme en mis consultorías, no verse a sí mismos. ¿Alguna solución por favor?
