HELP! Host to create a meeting but not attend | Community
Tash2022
  • January 24, 2022
  • 48 views
Hi all,
I was previously able to create a meeting in Zoom where anyone could join without the host attending or letting them in. Now when I create a meeting I need to login so other participants can join. Is there an easy way to set a meeting where I don't have to join as the host?
Thanks,
Tash.
    Hi @Tash2022
    Please can you check the following setting to see if it's enabled?
    • Sign in to the Zoom web portal.
    • In the navigation menu, click Settings.
    • In the Meeting tab, verify that Join before host is enabled.
    This support article provides additional information: https://support.zoom.us/hc/en-us/articles/202828525-Allow-participants-to-join-before-host
    Let me know if this resolves your issue? If so, don’t forget to mark the reply as an accepted solution!
    Thanks
