Help!Could Not get my meeting to launch...using MAC/Safari
I couldn't launch my meeting that I was the host of today even though I downloaded Zoom app again and reinstalled it (uninstalled the older Room app). I could get into Zoom, create the meeting but starting the meeting became an issue. Thanks!
    Hi @Cheryle , Are you getting an error message when starting the meeting?
    Yeah did you get an error message?
    @Cheryle Are you still having the issue? If yes, let us know what is the error message if in case you get one.
    Hi! Im getting the same issue. It's error 300. and wont get resolved using the reinstall method
    @JJplus was this working before? Are you using the Zoom desktop app or mobile app? Are you also able to sign in to Zoom via the web portal - https://Zoom.us and try to test if you can join the meeting from there. Also make sure you have the Zoom application updated.
