Help!!!
Will someone please tell me how to turn the volume on my i-pad up. When I am in a personal meeting room I cannot hear the participants.  The volume button is up to full capacity.  and I have spoken with the technicians at apple and they said everything was fine at their end.(we screen shared) I am at wits end.
Will someone please help!
    Hey @Dx211111111, interesting! With the volume all the way up you may be seeing something similar ⤵️
    Speaker off
    Disconnected Audio
    If you experienced the following, just tap on the speaker, and you'll see something like this ⤵️
    Or if you're disconnected from audio, just tap on Join Audio (Bottom-left corner). Hope this helps!
    Hey @Dx211111111, just reaching out! 🙂 Did this help you out? If it did, don't forget to click on the 'Accept as solution' button!
