Help
There was such a problem, during the broadcast, the text is not visible in the menu sub-items, I reinstalled the zoom 2 times, it did not help, Windows 8.1
    Hello!
    Can you share a screenshot of what you are seeing?
    Also, Zoom is not supported on Windows 8. Can you please upgrade to Windows 10 and let us know if that resolves the issue for you? Microsoft ended mainstream support for Windows 8.1 on January 9, 2018.
    Thanks,
    Micah
