Help | Community
Help
I did update for the windows 11 and my sound just work when the automatically adjust the volume is marked and have a delay before work right. Someone help me?
    I hope I didn't misunderstood you because your problem is a little unclear. Go to audio settings in the button beside your Mute/Unmute button. At the top, you can adjust your volume.
    Andrew4Author
    Its not impossible, the button don't movie
    Andrew4Author
    Its not possible*
    There are so many amazing things you can check here some detail about it on this page kindly help me about it. You can click on the link for further detail.
