Headset Mic doesn't work on Redmi Note 10 Pro
On my new Redmi Note 10 Pro, headset mic is not working when headset is plugged in.
The same headset works on the same phone but with other apps like WhatsApp, Telegram, and Hi-Q MP3 recorder.
The headset mic also works with Zoom on my old Redmi Note 9 Pro so this problem is specific to Redmi Note 10 Pro.
afrizaAnswer
Thank you for your reply..
Today I tested again and the standard workaround of leaving the meeting and rejoining again works..
The app seems to have been fixed since this workaround didn't work last time I tested.
January 1, 2023
hi afriza,
this support article may help you.
Troubleshooting speaker or microphone issues on your mobile device – Zoom Support
afrizaAuthorAnswer
