Headphones not working with Zoom... work with other programs. | Community
  • July 11, 2022
  • 19 replies
  • 1491 views
Whenever I use Zoom, my headphones don't work, the sound only comes out of the computer speakers.  I've searched for some audio setting that would allow me to use headphone as that seems like the logical problem, but I can't find those audio settings anywhere.  I use Zoom everyday, so it is imperative that I get this working.
    Bri
    Hi @Crossbow, and welcome to the Zoom Community! Could you tell me what type of headphones you're using? Are they wired or Bluetooth?
    CrossbowAuthor
    Hi Bri... thank you so much for taking the time to answer my question.  I was able to solve the problem directly with the headphone company.  I wish I could remember what they changed... something in System-> Sound in Windows 11.  I had the headphones plugged into an external monitor, and sound was coming out of both at the same time, or not at all.  To answer your question though, they are Bluetooth 😉
    I am having the same issue. I am using headphones from an old iPhone that work fine in all other devices with or without an adapter that I use for my iPhone11.  When plugged I get no sound coming from the headphones when on a Zoom meeting though when I use the same headphones for Teams meetings or Pandora or anything else the sound comes through the computer to me through the headphones only, not from the speakers on my laptop.
    Plug in HROEENOI headphones that plug into the USB not wireless and they do no work on ZOOM. I can hear videos playing on headphone but when in ZOOM I can not hear other people speaking through my headphones? I see there are not current answers to this issue?
     Is there an ETA for fixing this, or is the answer to use Microsoft Teams instead?
    Neither Sony wired headphones or Bose wired headphones or Apple earbuds work on Zoom
    I was having a similar issue most of June 2023. After checking with the help desk and looking up Sony resources for my headphones, I couldn't see anything. Then today I saw an earlier comment in this thread and went to System>Sound> found my device, whose settings and volume were on. Then I clicked on it to see further, and discovered that somehow it no longer had permission to work. Crazy - I never knew that menu existed but somehow the permission got turned off for the headphones. I turned it back on and now everything seems to work.
    I'm having this problem - I'm using Sony Bluetooth headphones, model MDR-XB650BT. They worked all last year and now not working on Zoom only.
    Asphalt Nitro MOD APK
    Hello all, after trying everything for months with this issue, I found a fix for my own situation so I hope it applies to others. Zoom customer service couldn't help after repeated contact, not could Sony (my headphone brand) or Microsoft. It turns out there's a reset process within Windows which can help - I came across someone who had the same issue, he took a look at my computer and this worked for me too. The issue was in MS settings, which on the surface were all fine. So when your headphones are on and connected, go to Windows Settings, then Bluetooth and devices, Devices, then under Related settings you should see your headphones selected under both the Output and Input sections. In my case, the volumes were in the middle range and everything looked fine here on the surface. This guy told me there is a glitch in MS, and you only need to toggle the volume down to zero in the output section, then return it to the level you want, and it resets the sound on the headphones somehow. It doesn't make any sense, but I did it and that solved my issue! Of course if you don't even see your headphones highlighted here, that would indicate another issue, but at least you could work from there. Hope this works for others!
    Hi, If your headphones work with other programs but not Zoom, try these steps: Check Zoom’s audio settings and make sure your headphones are selected as the speaker and microphone. Restart Zoom or your computer. Update Zoom to the latest version. Test your headphones in Zoom’s audio settings > Test Speaker/Microphone. Let me know if this helps!
