Jun 21, 2025 6:53 AM UTC
Guided soundbath - audio setting and 2 mics
Dear Community,
I am trying to manage settings in order to have a meeting (a yoga workshop) and tu guide a relaxation using some instruments . I use a Rhode mic for me and I have a Yeti Blue for the instruments .. I have managed the musicians option, it is all good, but actually I can't select 2 mics 🙂 Any suggestions for me to lead this musical relaxation and have 2 mics?... Many thanks!
Jun 25, 2025 7:51 AM UTC
As an audio and broadcast engineer I can tell you that computer audio can be very complicated.
Use any audio interface such as the Focusrite 4i4 to mix the mics for Zoom.
SofiyogaAuthor
Jun 26, 2025 7:52 AM UTC
y thanks ! yes apparently, I need a device for having 2 mics, will check fifths is worth it regarding my needs 🙂 Thanks again for your time!
