Green Screen Problem
Hello there, my image is showing in a  whole green tint. I've tried to run it in other platforms and apps and the image of my camera is perfectly fine. It' has to be something with Zoom specifically. I uninstalled zoom completely updated it, removed the acceleration hardware in video settings advanced, reinstalled the last zoom version and my camera is still in green color. I'm on Sonoma 14.2 (intel based). Please help!
EDIT: Finally the problem was solved. Had to buy another Mac, but I solved it. If you are running an old mac with Open Legacy Patcher, don't expect Zoom to work properly.
Thank you
DanHuber
DanHuberAnswer
have you checked in zoom settings if you have some filter selected? zoom settings-->background & effects-->video filters.
Hello! Is someone there??  HELP PLEASE!
DanHuber
DanHuberAnswer
To add to @DanHuber response, if you're using a green screen as your virtual background, you'll need to manually select your screen screen. The Knowledge Base contains information on Changing your Virtual Background image with the Recommended setup with a green screen. This will explain how to set this up for the best virtual background experience with your green screen.
