Force reset audio to default | Community
  • January 14, 2022
  • 37 views
Hi, I run a home recording studio and have been trying to be able to use Zoom for sharing my DAW (Digital Audio Workstation like Ableton Live, ProTools etc) with a client. The problem I'm facing is that once upon a time I changed an audio setting to Source Nexus (specialty software for this type of stuff) and now whenever I open the Audio settings section of preferences Zoom freezes and I have to force quit.
Is there a way to reinstall Zoom but force reset the audio settings to default? As of now any reinstallation still calls up those same settings. Any suggestions on how to force those audio settings to reset to default without having to open the Audio settings section of preferences?
    I have this issue too. Did you ever find a solution?
