Nov 23, 2024 1:17 PM UTC
Enabling original sound for musicians not working
Hi- I am in US and take guitar lessons with a teacher in UK. He records the lessons for me. He uses a windows computer(I believe)  and I use my Ipad pro (updated)  and though I have checked enable original sound for musicians both in and out of a meeting my teacher CAN NOT hear my guitar. We can speak to each other but as soon as I play he says my guitar cannot be heard. I can see and  hear his guitar.  I take my lesson in a quiet room. He says I am the only student he has this issue with!
i tried taking a lesson on my patio and when i played the recording some of the sound cut off intermittently.
Please help!
MGSRAnswer
Dec 3, 2024 2:37 PM UTC
Hello there,
I'm sorry for the late response.
It's possible that the noise suppression on your device is turned on.
You can try the following.
1. right click on the taskbar sound icon > select "Sound Settings" > More Sound Settings > right click on the currently used microphone device > Properties > switch to the "Enhancements" tab > uncheck "Noise Suppression ".
2. Right click on the taskbar sound icon > select "Sound Settings" > More Sound Settings > switch to the "Communications" tab > check "Do nothing" >Apply >ok.
Please let us know if this helps or if you need further assistance.
Nov 26, 2024 5:09 PM UTC
Had same issue.  Not caused by Zoom settings.  Resolved by modifying sound settings on my laptop.  Unfortunately, I can't remember exactly what settings.  Problem had to do with default settings in Windows 11 (changed from Windos 10) that override Zoom settings.
MGSRAnswer
Hello there,
Nov 16, 2025 6:20 AM UTC
Hi Mark. Your reply here is not helping me, because your instructions on how to turn off "noise suppression on your device" don't seem to correspond with an iPad Pro, which is the device the original poster (BeCart) said they were using Zoom on. Your instructions are to "Right click on the taskbar..." which is not something that can happen on an iPad, as far as I know. Can you please explain how to solve this problem on an iPad when simply selecting "Original sound for musicians" isn't helping?
