Librarycat
Sep 8, 2022 2:26 PM UTC
Embed passcode in meeting link for one-click join not working - requiring users to put in a passcode
Hello!
I am confused by the embed passcode for one-click. I have this option turned on. Yet, at a meeting the other day, everyone reported that they had to enter the passcode when joining from the link. This is the first time anyone has said they needed to enter a passcode when joining from the link.
I am wondering if one of my settings is wrecking havoc with the one-click setting? I have attached two screenshots with my settings.
Thank you in advance, I appreciate your help!
    Librarycat
    Sep 15, 2022 2:17 PM UTC
    Has anyone else had this problem? I am guessing not since no on has replied!
    Dec 1, 2024 5:50 PM UTC
    Yes.  Even though the "edit" function says the Link should not require a passcode, it does.
    The only workaround I have found is to set "Waiting Room" on.
    Not an optimal solution since now I must stay focused on the screen to give people access.
    This has worked correctly for years, but does not now.
    Apr 14, 2025 1:20 AM UTC
    Embedding the passcode should allow participants to join with one click. As backup it's a good idea to include the passcode when you share the link with attendees in case they are prompted. If you want to automate this there is a Zoom app, Salepager, that lets you send Zoom invites and reminders that include by the passcode by default.
    Apr 8, 2023 12:22 AM UTC
    Yes, I have exactly the same problem. Doesn't anyone answer these bugs?
    Jun 8, 2023 7:47 PM UTC
    did you get an answer to this?  I have been having this issue for a long time and cannot fix it....
    Librarycat
    Jun 9, 2023 7:19 PM UTC
    No, no answer. You'd see it here. Hardly any of these questions get answered it seems, although there a few people on here who are helpful. The rest sound like bots.
    Sep 21, 2024 3:07 PM UTC
    I've now posted with about 5 different questions and NONE of them get answers although they all bring up that complaint from others—no useful replies. What a waste of time, especially when other free platforms have arrived. Thanks for nothing, Zoom!
    Librarycat
    Sep 22, 2024 7:37 PM UTC
    Actually, I think this issue has been resolved with one of the many Zoom upgrades. I no longer have this issue.
    Dec 1, 2024 5:51 PM UTC
    As of today, 12/1/2024, the problem persists.
    Apr 3, 2025 12:08 AM UTC
    Having the same issue.
    Apr 10, 2025 2:20 PM UTC
    Hello @ctesar,
    I'm sorry about the inconvenience you experienced.
    Kindly check out this article for the requirements and steps to embed meeting passcodes.
    Sep 26, 2025 7:16 PM UTC
    Except this doesnt actually work.  Our settigns are as described in that article.
