New Member
Nov 11, 2026 5:57 PM UTC
echo problem
When I join a meeting, the participants immediately hear their voice is echoing. They don’t hear my voice echoing. What can I do to stop this other than mute myself
    TrishGallardo
    Nov 12, 2026 11:50 AM UTC
    Hi Pat,
    Here's what's happening and how to fix it: when other participants hear an echo of their own voice (but you don't hear your own voice echoing), it usually means your microphone is picking up the meeting audio from your speakers and sending it right back to them, even though you can't detect it on your end
    Try these steps, in order:
    • Use headphones or earbuds with a built-in mic — this is usually the quickest and most effective fix, since it prevents your mic from picking up speaker output at all
    • Check your audio device selection by clicking the arrow next to the Mute button in Zoom and confirming that the correct speaker and microphone are selected
    • Lower your speaker volume and physically move your microphone farther away from your speakers
    • Check for duplicate audio connections — make sure you haven't joined the meeting audio on both your computer and your phone, and confirm no other nearby device in the room is also connected to the same meeting
    • Reconnect or swap your audio hardware — if you're using an external headset or mic, try unplugging and reconnecting it, or test with a different device
    The root causes are typically a microphone picking up nearby speaker output, multiple devices simultaneously connected to meeting audio, or echo cancellation not functioning properly
