May 5, 2025 5:02 PM UTC
Deactivate zoom audio processing!
We need zoom to allow us to bypass built-in audio processing like original sound, noise suppression or live performance for musicians. Those features okay but not in every scenario. We find it messing with our mix streaming live performances. It would be great if we can choose whether we want to use this features or not. So maybe in future updates we could have something like “bypass”, “deactivated zoom processing” or “computer raw audio”
May 7, 2025 5:37 AM UTC
As a sound and broadcast engineer I can tell you that computer audio is very complicated, far more complicated than video. There are reasons for doing audio certain ways (even when there are lots of other choices) to get the right kind of performance. It is not clear what you are attempting to do. I do Zoom broadcasts all the time with great stereo audio music. I have even streamed from Zoom to Facebook and YouTube without issues. Most likely you are not using proper hardware or the hardware and software is not properly configured. And most likely Zoom is not the cause of your issues.
