Apr 23, 2025 6:31 PM UTC
Cut and Paste for Addresses
I am not sure what I have done to my Zoom app, but I no longer have the capability to cut and paste an email address into a meeting invite. It must be my settings because I used to be able to do this, and Zoom would never remove something like this from their application. Can anyone tell me what settings I need to re-enable this functionality?
Aug 12, 2025 12:47 PM UTC
It sounds like your Zoom app settings may have changed, possibly after an update. Try these steps:
Open Zoom and go to Settings.
Check the General or Meetings section to ensure copy and paste is allowed.
If using a browser version of Zoom, make sure clipboard permissions are enabled in your browser settings.
Restart Zoom after adjusting settings.
If the problem continues, reinstalling Zoom usually restores the default features.
Aug 17, 2025 1:19 AM UTC
This reflects an update to the settings. You can still type out the email addresses manually. It might also be worth reinstalling the app to see if that resets the previous settings. Alternatively there is a Zoom app, Salepager, that lets you copy and paste emails into meeting invites.
Aug 18, 2025 8:04 AM UTC
It is not clear what device, OS, or Zoom version is being used or how you are trying to cut and paste. I am using windows 11 on an asus PC with Zoom 6.5.9. Clicking invite from the participants menu I can paste an email address.
