Create meeting problems
Every time I create a meeting, the Zoom Topic section reverts to no spaces between the Zoom topic.  Also, each time I scroll back up to add spaces, the Zoom settings revert to basic (Like if I set it to have cameras on, it’ll reset). What is going on?
    Hey @Kgrigs are you scheduling meetings within the Zoom client itself or within the Zoom web portal? Your scheduler settings are synced from the Zoom web portal if scheduling from the Zoom client.
    Hey @Kgrigs, are you still having issues? If not, great! Just don't forget to mark my reply as the solution. If you still are having issues I can definitely further help!
    I am having a similar issue with one of my users.
    User is using the zoom outlook plugin.
