Feb 9, 2024 8:21 PM UTC
Crackling and popping in sound when using USB speaker/mic
After my zoom updated to 5.17.5 (29101), I started to notice crackling/popping from my USB speaker/mic (Jabra Speak 510).  The crackling/popping comes and goes and sometimes is really bad and sometimes is minor. It doesn't happen when I send audio through my Macbook speakers, only when using the USB speaker.
I've tested various settings, and it seems to be better if I switch audio settings to
- Original sound for musicians
- High-fidelity music mode: On
- Echo cancellation: On
- Stereo audio: Off
But even with the above settings, the crackling/popping still happens sometimes (just less frequently).
Has anyone else seen something similar?
Feb 10, 2024 4:50 PM UTC
Hi j3d,
Do you have the latest firmware/software installed on your Jabra speak 510?
Jabra Speak 510 | Jabra Support
try removing and reconnecting your usb connections from your Jabra speak 510 and your mac book.
Please also see
Troubleshooting speaker or microphone issues in the desktop client - Zoom Support
Troubleshooting audio issues - Zoom Support
Troubleshooting audio with USB extenders - Zoom Support
CarlaA
Feb 16, 2024 4:42 PM UTC
Hi @j3d, thank you for posting to the community! Did you find @Eliot's reply helpful? If so, please mark the reply as an accepted solution. Thank you!
j3dAuthor
Feb 16, 2024 4:53 PM UTC
Unfortunately neither of @Eliot's suggestions helped.  I tried force updating the firmware and I've tried connecting the Jabra to multiple USB ports.  I'm able to reproduce the problem in Facetime as well as Zoom, so I'm talking to Jabra support now.
Jan 21, 2025 8:39 PM UTC
I have the same issue with my jabraspeak 510 USB and zoom workspace, the sound is crackling and very bad. Issue only happens with zoom, the jabraspeak works fine with other applications.
jabra speak 510 updated to latest firmware : 2.32.0
zoom 6.2.7
Jan 21, 2025 8:44 PM UTC
I have the same issue with usb jabra speak 510+ and zoom workspace.
jabraspeak 510+ updated to the latest firmware version (2.32.0) and
zoom is 6.2.7. Issue started after updating zoom but I don't remember from which version
best wishes
Olivier
Jan 21, 2025 8:54 PM UTC
I was eventually able to solve this by changing the hub to which my Jabra was connected.  Kind of a bummer because I liked my old hub.
